GC Tuner / ShopSFM
Sponsor:  GC Tuner
“ShopSFM” is composed of a group of enthusiasts who not only have a vast knowledge of the parts we sell but also are dedicated to providing the best price and customer service possible. We sell products ranging from Import, Domestic and European vehicles.
http://www.GCtuner.com
|| SHOPSFM || DGR Coilovers w/ Free Custom Spring Rates, Free Shipping & LIFETIME WARRANTY
Old Jan 9, 2012 | 01:34 PM
project jayden's Avatar
Vehicle: 2010 Hyundai Genesis Coupe 3.8
Default || SHOPSFM || DGR Coilovers w/ Free Custom Spring Rates, Free Shipping & LIFETIME WARRANTY
The Sport kit designed and built from the ground up on the vehicle. We selected the proper sized shocks to work with proper height springs to maximize the most usable bump and droop travel. Comes with our hassle free LIFETIME WARRANTY and tech support. Great suspension for a daily driver/ weekend racer!
On almost all applications (except A-Arm and Multi-Link), the DGR kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber allows you to easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The adjustment of the damper is an easy adjustment via a knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. DGR adjustable dampers make suspension adjustments easy to tune to match your driving needs, be it comfort or weekend auto-x.
The height adjustment is is handled by the aluminum alloy lock rings for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling (and sometimes higher than OEM) or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car's handling capabilities.
With a DGR kit, you will immediately notice the construction quality and the durability of the kit. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong LIFE-TIME warranty.
These are with upgraded springs:
Street Kit:
1) 30 way, Double Adjustable (Damper/ Rebound)
2) Mono-Tube Construction
3) Full Height Adjustable
4) Camber Plates* with Koyo spherical top bearings or Aluminum Alloy top hats with high durometer bushings
5) Cold Wound, Heat treated Coils
6) Customizable spring rates, at NO ADDITIONAL CHARGE (plan for roughly 14 days for delivery on custom orders)
7) Customized kits are valve matched to the springs
8) DGR Suspension systems are NOT rebadged kits currently on the market.
9) Top spherical bearing is from KOYO in Japan
10) Seals are from NOK in Japan
11) Fork oil is from IP in Italy
12) * Track setup (optional + $100 stronger valves and stiffer spring rates )
13) * Road Magnet upgrade (optional + $300)
14) FREE CUSTOM SPRING RATES
15) LIFETIME WARRANTY
KITS AVAILABLE:
97-00 ELANTRA
02-UP MATRIX
97-01 COUPE
02-UP COUPE
05-UP TUCSON
01-05 ELANTRA
02-UP TIBURON
03-UP GETZ
99-UP ACCENT
00-UP EQUUS
09-UP I30
08-UP GENESIS Coupe
09-UP ELANTRA
06-10 AVANTE
PM FOR BEST PRICING!!!
Old Jan 10, 2012 | 10:52 AM
bump to the top!
Old Jan 16, 2012 | 10:45 AM
These are going on the project car very soon
Old Jan 20, 2012 | 11:17 AM
couple of pics:
Street Kit:
Old Jan 23, 2012 | 03:46 PM
bump to the top for one of the best coilovers out there
