How did you run your lines?
Old Nov 16, 2011 | 12:55 PM
Angelos's Avatar
Vehicle: 01 Tiburon
Default How did you run your lines?
Did everyone run their n2o lines under their car? I was reading a magazine that had a n2o-101(intro course) that showed lines being run down the interior of the car.
Old Nov 16, 2011 | 01:06 PM
blitz's Avatar
Vehicle: 97' Hyundai Coupe
U don't want lines inside the car if u ask me ! It's easy and safe to run'em under the tib
Old Nov 16, 2011 | 02:48 PM
dont have no2 but if i was gonna run it i would use the stock drain holes under the backseat. they have rubber grommet that blocks water but you could cut hole big enough for lines in those and just run them with the brake/fuel lines on either side of the car.
Old Dec 28, 2011 | 03:58 PM
Seer's Avatar
Vehicle: 2012 Ford Mustang Shelby GT500
NHRA and IHRA regulations state the line must be run outside of the car, also the bottle must be equipped with a blow down tube unless the bottle and the driver are seperated by a firewall (your trunk is not this).
You want the bottle also to be facing forward (valve toward the engine) and the bottle's pickup tube facing downward. Typically this means the bottle's label should be facing up.
