2.4 alternator
Old Jun 25, 2011 | 03:21 AM
kippax's Avatar
Vehicle: 2002 santa fe 2.4
Default 2.4 alternator
any one got full details on how to remove one.
every thing is disconected, but it will just not come off the mounting.
Old Jun 25, 2011 | 05:08 AM
SR Tech's Avatar
Vehicle: 2011 Tuscon
I can't remember if i've ever pulled one before, but as along as you have all the bolts out and the wiring undonw its more than likely the dowel pins holding it in place. Just pry it away with a bar.
Old Jun 25, 2011 | 03:52 PM
If it is like the 2.0, there are two ears on the alternator that go on either side of a mounting boss, and they hold tight. If all the bolts are off, pry with a big screwdriver and spray with penetrating oil as necessary.
Old Jun 26, 2011 | 10:23 AM
kippax's Avatar
main problem is, the pivot bolt head fouls on a mounting block.
the bolt has to be removed inboard and not towards the wheel arch.
other sites have said that this bolt rests in a `c`shaped bracket
but i cann`t feel any such opening.
ihave plenty of play but can not can any kind of movement to suggest that the alt is going to move
Old Jun 26, 2011 | 09:14 PM
Without having the car in front of me, this is about as much help as I can provide:
To see the online Shop manual for your car, use Internet Explorer and get a free account to login to http://www.hyundaitechinfo.com/
Navigate to SHOP > SANTAFE(SM) >2002 > G 2.4 DOHC > Engine Electrical System > Charging System > Alternator > Repair procedures
To me, that looks an awful lot like the same mounting setup as on an RD's alternator (mine):
The above image is part of a removal/replacement DIY you may find helpful even if it is not for your car in particular: https://www.hyundaiaftermarket.org/f..._1#entry563387
