Accent GT radiator with a beta swap
Old Mar 23, 2011 | 01:28 PM
OzoneGT's Avatar
Vehicle: 1999 Accent GT
Default Accent GT radiator with a beta swap
Does anybody know if a stock 1999 Accent GT radiator and fans will allow sufficient cooling for a beta swap or will I have to use a different ones? I was thinking about getting the Flex-a-lite slim fans. Anyone use them on their car?
Old Mar 23, 2011 | 03:29 PM
Juanra's Avatar
I have the OEM radiator with the OEM fans and I don't have any problems.
The only modification on the fans, is that they both turn on by temperature (by default is only the engine fan.
And my Beta has OEM thermostat.
Old Jul 30, 2011 | 01:41 AM
sPiKiE's Avatar
Vehicle: 97 Beta X3 GT
I just put in the 3rd Rad into my beta x3 two weeks ago.. on both the plastic at the top near the filler cap crack..
Old Jul 30, 2011 | 01:45 AM
i've got the stock half radiator and fan in mine. works fine, even with the a/c condensor in front of it. i do have a spare full radiator from an X3 in my garage, but there isn't a mounting point to accomodate a full sized rad.
i wouldn't worry bro.
Old Jul 30, 2011 | 12:58 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
^^Lucky you^^ I have the half radiator as well and on hot ass days running the a/c will get me in trouble cuz my car will overheat.
Old Aug 2, 2011 | 12:23 AM
incidentally, i just removed most of my a/c gear. feelsgoodman. i'm not keen for removing the dash to get rid of the rest of it.
