Testing Forum A place for you test out signatures, UBB code, or HTML code.
Test Pic
Old Sep 8, 2009 | 08:49 AM
kite992000's Avatar
HI All
Just Thought I would add to this great thread. (even though its old)
The SMT6 is adjusting Timing,
Logging wideband (I intend to later use this input to read the Intake Air Temp and adjust Map
Adjust STD ECU Map
Runs extra Injectors
Note the Crank Sensor Differentail Amp. I had to Add this externally as the SMT6 cant use the Balanced Iginition input as it shares it with the Injector Ground.
I hope this helps anyone wanting to adjust Timing and also run extra injectors at the same time
Cheers
