ARK Performance
Sponsor:   JLB Motorsports
http://www.arkperformance.com
Ark Dt-p Coilover In Stock !
Old Apr 11, 2007 | 04:19 PM
ARKRacing's Avatar
NEW Arrive item !!
ARK DT-P Coilover System for 00-01 Tiburon !!
ARK Performance brings innovate premium quality damper kits that give precise comfort and balanced handling cornering to sophisticate drivers without loosing there performance results.
ARK damper kits offer different series for your driving situation. SP Series was designed for all your driving conditions with greater performance. This full length adjustment system allows you to set various set-ups to meet different road conditions. And hard rubber upper and lower mount design in SP series absorb noise and vibration to the cabin for quite operation while still offering minuteness suspension proofing. DT Series was developed primarily to serve maximum handling for experienced drivers. This preminum aluminum construction series with special coat on the thread ensure to resist rust and corrosion. And spring rates are tuned to provide high stability and favorable handling characteristics with a neutral front and rear balance.
ST-P
- 0-16 Levels of Adjustable Damper
- rubber upper and lower mount
- Spring Rates: 3kg/mm to 14kg/mm
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Mono-tube shock design for quick reacting and quite dampening operations.
- Electroplated body for protection from corrosion and rust
- All coilover damper kits come with 15months manufacture-defect warranty.
- All Hardware is Included
DT-P
- Pillow Ball Top Mount w/ adjustable camber
- All rates from 3kg/mm to 14kg/mm are kept in stock
Old Apr 11, 2007 | 04:21 PM
xxxmonoxidechild's Avatar
oOoo......
are they gonna be priced about the same as the ones you sell for the GK?
Old Apr 11, 2007 | 11:17 PM
bigeyes.gif 32.gif hypnotized.gif how much?
Old Apr 12, 2007 | 10:47 AM
ARKRacing's Avatar
Retail Price $ 1699.00
Special Price : $1499.00
Thanks
Old Mar 18, 2008 | 11:01 PM
BlueSpanishShark's Avatar
Vehicle: 2000/Hyundai/Turbo Tiburon
Do you still have the DT-P's in stock? I'm going to buy in the spring time. Also you still have that dealer in Edmonton Alberta?
Old Apr 9, 2008 | 01:06 PM
ARKRacing's Avatar
<div class='quotetop'>QUOTE (BlueSpanishShark @ Mar 19 2008, 05:01 AM) <{POST_SNAPBACK}></div><div class='quotemain'>Do you still have the DT-P's in stock? I'm going to buy in the spring time. Also you still have that dealer in Edmonton Alberta?</div>
YES , we do. And Forum price not valid our distributor .... It is only from ARKspeedracing.com
Thanks
Old Jul 11, 2008 | 04:05 PM
Looks good...now to get them out of the box and on to the car.
By the way, very fast service....nice work.
