misfire in #4 cylinder.
Old 07-13-2002, 08:47 AM
2 UNIQ's Avatar
Default misfire in #4 cylinder.
I keep on getting a Misfire in Cylinder #4 all the time and car idles and runs crappy.I have to keep on replacing the spark plug or it to run OK again!!
I have changed my plugs and my wires are still good.I have Vi Teck wires in!!
Random i think your experiencing the same Misfires as i am and was wondering if your problem has been rectified!!
Any help would be appreciated!!
Old 07-13-2002, 06:00 PM
Random's Avatar
I get mis-fires all the damn time. Change your plugs every 10 miles if you want, you'll keep getting them. Change your wires to 70mm super conductor pure carbon, you'll still get them.
The tuning is the problem. The ECU *guesses* which cylinder is mis-firing based off the crank and cam sensor, and when the knock sensor goes off. It could be a late, post combustion event in #1 caused by running rich and the waste spark, or it could be pre-ignition in #3, but the ECU blames #4.
I get misfires on all 4 cylinders, and also a *random misfire*. No it's not *mine*, it means the ECU can't tell which cylinder is phucked up, so it just gives a *random misfire* error.
Tuning is the only fix (short of ripping the turbo off). If you drive hard, often, you'll aquire misfires on all the cylinders. Mine usually happens on #1, but the other 3 cylinders get their share, with the occasional *random* misfire.
The Supercharged engine gets them too. I blame it on overfueling, and the waste spark igition system. (I may be 100% wrong, but that's my semi-educated guess).
Old 07-13-2002, 08:57 PM
Jon
Jon's Avatar
I wonder if the chip has problems understanding the map or maf sensor reason being i get no misfire problems but all the US cars seem to get this problem. But no matter how much i changed the pressure regulator at more than 3/4 throttle it still looses power uk spec.
just a thought i might be wronge
One question whats the colour of the carbon on #4
reason i ask is if you have to keep replacing #4 plug maybe the fuel from the 5th injector isnt mixing properly and making it to the furthest cylinder causing it to run lean and eat the plug due to heat.
Old 07-14-2002, 03:47 AM
Random's Avatar
Mine are usually black. Carbon black. Running way to fricking rich black. (all 4)
Jon- I know you said money was tight right now, but if/when you get a chance, consider removing the 5th injector, going to a set of 4 350cc or 440cc injectors, and then having the uni-chip retuned to accomodate the injector size change. It is capable of doing that.
Old 07-14-2002, 04:08 AM
Jon
Jon's Avatar
That is one of my plans as im more worried about getting a good mixture to all four cylinders last thing i want is a hole in number 4 wall.
I pulled my plugs to see how they all were and i was well surprised they were all exactly as they should be dark brown ring of carbon on the rim and going lighter to the very clean tip. Only an indication i know but it says to me that the regulator is set about right. I just need to get the programme toned down in the chip at top end if i remember right its set to about +50 at the top. with the open loop part thats probably way to much.
I wont ask you what injectors to use etc because i know its been covered and i dont want a newbee arse rippin LOL.
Old 07-14-2002, 08:16 AM
2 UNIQ's Avatar
Random!!
I also pulled my plugs out and they were also all BLACK full of Carbon.The tip was brown though.
This indication is CLEARLY showing EXTREMELY RICH because my car has not been tuned yet and this would explain the misfire problems we are both having.
I just recieved my NEW O2 housing from ALipine on Friday so i will be installing it in excatly 2-3 weeks.They were KIND enough to send me a NEW O2 housing BORED OUT with a bigger Flapper.I believe he machined anywhere between 2-5mm to eliminate my Boost creep and hopefully this will rectify the problem.
Once everything is installed i will Dyno my car with the S-AFC and 440cc injectors i have and will post the results for you guys.
Im running SUPER RICH Now because i installed my new Walboro pump and currently im at 32psi at idle and at WOT it hits 90PSI which is so HIGH.
I believe the reason for this is because i dont have a stock regulator in and all i have is the RRFPR from Alpine and tahts whats causing the extreme high pressure.Im installing an AEM 1:1 ratio FPR to eliminate the bouncing of the Fuel pressure at idle.
Anyways i will post results in about 3 weeks exactly and they you guys know smile.gif smile.gif
Old 07-14-2002, 08:40 AM
Dopeskills's Avatar
So basically the only way to take care of the misfire problem would be to upgrade to a better engine management system (haltech, etc) and have it tuned properly???
and as Cheuk commonly recommends, *tuned with a wide band 02 sensor*
Old 07-14-2002, 12:12 PM
Cheuk in Seoul's Avatar
It's possible that with seriously anal tuning with piggy back ECU's and lots of time with a wideband you could get the fueling right for most situations. It's just that after a while with multiple bandaids.. it's never just right... it's as expensive as a stand alone.. and it's more difficult to tune because you've got to adjust all the piggybacks.
2UNIQ, I also believe you are running too rich and the over rich condition is fouling your plugs.
What exactly are you running for fuel? RRFPR, larger injectors and S AFC?
2UNIQ... Get that thing TUNED!!!
Old 07-15-2002, 12:59 AM
Random's Avatar
The problem with the alpine kit as delivered is the tuning, or lack thereof of the uni-chip, and the 5th injector.
in order to keep the cost of their kit low, alpine has you reuse the 4 stock injectors, and then uses 1 large 340cc injector as a *5th* injector BEFORE the TB.
This 5th injector, and the 4 regular injectors need to be tuned by proffesinals familar with the UniChip. Alpine has taken 4 tries at tuning my unichip with no luck. It's going to go to a *professional* tuning shop next. I'm also dumping the 5th injector and going with 4 550cc injectors. The *head spacer* is also being ditched in favor of 8.4:1 ratio pistions. This should solve the misfiring, and the rich condition. (he he...should. Cross your fingers).
