2009/2010 Genesis Coupe Specs
Old Nov 23, 2009 | 06:01 PM
Default 2009/2010 Genesis Coupe Specs
GENESIS COUPE SPECIFICATIONS
-- Configuration: Front engine, rear-wheel drive
-- Wheelbase: 2820 mm / 111.0 inches
-- Overall length: 4630 mm / 182.3 inches
-- Overall width: 1865 mm / 73.4 inches
-- Overall height: 1380 mm / 54.3 inches
-- Wheels: 18-inch or 19-inch five-spoke
-- Engine types: 3.8-liter V6 or 2.0-liter 4-cylinder turbo
-- Est. horsepower V6: 306 @ 6,000 rpm (regular fuel)
-- Est. horsepower V6: 310 @ 6,000 rpm (premium fuel)
-- Est. torque V6: 263 lb. ft. @ 4,700 rpm (regular and premium fuel)
-- Est. horsepower 2.0t: 212 @ 6,000 rpm (regular fuel)
-- Est. horsepower 2.0t: 223 @ 6,000 rpm (premium fuel)
-- Est. torque 2.0t: 217 lb. ft. @ 2,500 rpm (regular and premium fuel)
-- Block & head materials: aluminum for both engines
-- Valvetrain: DOHC for both engines
-- Valve timing: continuously variable valve timing for both engines (Dual for 2.0t)
-- Estimated 0-60 mph V6: under 6 seconds
-- Transmission types: 6-speed manual, 5-speed automatic (4-cylinder) or 6-speed manual, 6-speed automatic (V6)
-- Front brakes: 12.6-inch (standard) 13.4-inch (Brembo package)
-- Rear brakes: 12.4-inch (standard) 13.0-inch (Brembo package)
-- Front calipers: single piston floating (standard), monobloc four-piston (Brembo package)
-- Rear calipers: single piston floating (standard) monobloc four-piston (Brembo package)
-- Limited slip differential (Optional)
-- Est. top speed: 149 mph (V6), 137 mph (2.0t)
-- Base curb weight: 3549 lbs. (V6); 3439 lbs. (4-cylinder)
