Hyundai/KIA RSS Feeds RSS Feeds and News Links From Around The World...
Multiple Hyundai recalls for brake lamps and rust issues affect nearly 1M units
Old Apr 20, 2009 | 12:53 PM
Hyundai News Bot's Avatar
Vehicle: Hyundai
Default Multiple Hyundai recalls for brake lamps and rust issues affect nearly 1M units
Filed under: Recalls/TSBs, Hyundai
The National Highway Traffic Safety Administration (NHTSA) and Hyundai have initiated recalls on 963,305 vehicles as part of four separate campaigns. The first recall, blanketing over one half million late-model vehicles, is nationwide. The other three recalls, all corrosion-related on older vehicles, are limited to the regions of the country where salt is used to de-ice roads in the winters.
The most widespread recall, affecting up to 531,894 2005-2008 Accent, Azera, Elantra, Entourage, Santa Fe, Sonata, Tucson, and Veracruz models, is NHTSA Campaign 09V122000. It is focused on a malfunctioning stop lamp switch that may prevent brake lights from illuminating when the pedal is depressed (the same switch may also cause them to stay lit after the brakes are released).
The second recall, affecting up to 175,765 1999-2004 Sonata, XG300, and XG350 models, is NHTSA Campaign 09V124000. That recall, limited to America's so-called "Salt Belt" states, is centered around potentially excessive corrosion of the front sub-frame due to winter road salt applications. If unnoticed, the lower control arm may separate from its mount.
The third recall, affecting up to 170,610 2001-2003 Elantra and Tiburon models, is NHTSA Campaign 09V125000. Also limited to the salt-belt states, the affected component is a failed lower control arm due to excessive corrosion.
The fourth recall, affecting up to 85,036 2001-2003 Santa Fe models, is NHTSA Campaign 09V123000. Again limited to to the Salt Belt states, the recall is centered around the possible internal corrosion of the rear trailing arms in the vehicle's suspension.
In all four recalls, Hyundai dealers will inspect, repair, and replace defective or damaged parts at no cost to the owner. In some situations, rust-proofing material will be added to chassis areas to arrest the corrosion process. Owners of affected vehicles may contact Hyundai Customer Service at 1-800-633-5151, call the NHTSA Hotline at 1-888-327-4236, or visit SAFERCAR.GOV. Press releases after the jump.
[Source: NHTSA]Continue reading Multiple Hyundai recalls for brake lamps and rust issues affect nearly 1M units
Multiple Hyundai recalls for brake lamps and rust issues affect nearly 1M units originally appeared on Autoblog on Mon, 20 Apr 2009 14:20:00 EST. Please see our terms for use of feeds.
Permalink | Email this | Comments
View the full article
Old Apr 20, 2009 | 01:14 PM
Interesting...wonder if Hyundai owners will be getting a notice in the mail, or if they just have to take their cars in to be fixed.
Old Apr 20, 2009 | 02:02 PM
