Need Oxygen Sensor Wiring Help Asap
Old 10-29-2009, 02:44 PM
Ok on my 2000 I dont have a rear o2 connector and there hasnt been a sensor there, just wires. I need someone to go out and look for me which wire connects to what.
It will be to a bosch o2 sensor, the colors are:
white - heater
white - heater
black - signal
gray - ground
All the wiring diagrams I can find dont have my wire colors which are:
brown
yellow
red/white
pink/white
Thanks!
Old 10-29-2009, 02:48 PM
likeyoumeanit's Avatar
hey, that's how mine are, unfortunately, my tib is 170 miles away
Old 10-29-2009, 02:56 PM
Hmmm, did I post these when I did my sensor relocation DIY? I can't remember man.
I can tell you when I get home I think.
Old 10-29-2009, 03:13 PM
I searched around but didnt see that thread. Ill check. Thanks
Redz, if you (or anyone else) could check that would be great. I found the DIY and it doesnt list the colors. Thanks
Old 10-29-2009, 04:28 PM
My rear o2 sensor is currently IN the car, BUT I've got my wideband out of the car, and it's wired PnP, so I can give you pics and all if you'd like.
Between that and a wiring schematic from HMAService, you should be good.
Old 10-29-2009, 06:00 PM
I do need some good pics of the LC1 all wired in to be PnP.
If anyone can check the rear wires for the O2 I still need that. HMAService had the wrong colors.
Old 10-29-2009, 06:24 PM
ScoupeLS's Avatar
Vehicle: 2003 Tiburón GT
the problem is that the wire colors differ year to year. i have like 3 different O2 pig tails and all of them have diffent colors.
hopefully this might will help...
Old 11-04-2009, 11:33 AM
For future reference if anyone searches for this the correct wiring is:
pink/white goes to white (heater)
red/white goes to white (heater)
yellow goes to black (signal)
brown goes to gray (ground)
Old 05-12-2011, 03:24 PM
bigfishmoney's Avatar
any1 know the wiring of yellow/green, red/white, gray, and black?
wiring from the ecu side to bare wires from oxygen sensor
Old 05-12-2011, 06:07 PM
bump
